Tonijim's avatar
Tonijim
MA Auto Inspections
Looking for a MA state vehicle inspection site in the Boston metro area for our 32 foot Thor on a Ford E450 chassis. Our recent inspection station no longer does motorhomes.
Thanks
  • I recently purchased my first motorhome, and I used the locator that blangen posted above to find an inspection station. There were plenty of options. It worked out well for me--the repair facility that I was hoping to use was on the list, and was able to both inspect and repair the Ford E350 chassis. Good thing, because just as I was pulling in for the inspection, a brake line blew and they were able to do the repair. Since then, they've done other work for me and they are my go-to mechanics.
  • Apparently, MA doesn't make it easy... depends on vehicle weight. Here's from the MA DMV:
    An Auto Home is defined as any motor vehicle originally designed or permanently altered and equipped for human habitation which is not used to transport property other than that property used for human habitation or camping purposes. These vehicles can be identified at inspection stations by the display of Auto Home (“Camper”) plates.
    These vehicles undergo a non-commercial safety and emissions inspection regardless of the GVWR of the vehicle, and the inspection fee is fixed at $35. In other words, inspection stations are prohibited from charging an hourly shop rate when inspecting Auto Homes.
    For Auto Homes with a GVWR under 10,000 lbs, the inspection station must be a Class A, Class B or Class D station.
    For Auto Homes with a GVWR between 10,000 lbs and 26,000 lbs, the inspection station must be a Class B, Class C, or Class D station. Additionally, the inspector must have completed commercial training.
    For Auto Homes with a GVWR over 26,000 lbs, the inspection station must be a Class C, Class D or Class E station. Additionally, the inspector must possess a commercial driver’s license (CDL), and have completed commercial training.
    Check the Station Locator to find stations that are authorized to perform Auto Home inspections. You may also want to call your inspection station before you go to ensure the facility and their inspectors can accommodate your vehicle type.
