Karsty
Jun 16, 2014Explorer
"RoyB" ... it is definitely not the black water tank. It is clean as a whistle and never used. I am using a composing method right now.
The macerator pump and switch worked fine a couple weeks ago when I drained the gray water. Just not working now. The fuse is fine ... so I am thinking switch or as someone suggested from another page ... perhaps a wire. He had a similar problem and it was a loose wire from the pump motor.
Just have to find a way to get under the darn thing. Looks like a set of DIY ramps are in order to get this thing up off the ground enough to get under and see what is what.
Thanks for your suggestions.
38,771 PostsLatest Activity: Apr 15, 2026
