Karsty
Aug 04, 2014Explorer
pickerel cove wrote:
Karsty - I'm anxious to hear what your solution was. We have a 2010 ERA and the macerator stopped working when we were on a 3 week vacation. My husband couldn't fit under ours either. I took it to an RV shop and they didn't have a pit or lift (I should have asked first), and they used 4 stacked 2X10s of graduating lengths and beveled edges to help smooth drive on.
Our pump was actually making pump noises and was not blocked on the inlet side. We also use the correct paper and no flushing anything other than that.
Once replaced the pitch and sound was totally different than it had been and all is working now. Unfortunately I didn't ask for the old one so I can't tell if it was hair inside the macerator or a power issue. Not happy to know that this may be a never ending issue.
In my case it was the macerator pump switch in the water compartment area. They replaced that and all seems well. The first time it was clogged at the impeller and would blow a fuse every time I turn the switch on.
I am not at all impressed the the macerator pump way of emptying and users of the ERA need some kind of emergency dump outlet. Just another way that Winnebago has scrimped on these units in my opinion.
Your symptoms sound different than mine ... it would have been nice to have kept the pump and have it rebuilt and keep as a spare.
I don't use the black tank on mine unit at all. Since I travel alone I will stop along the way and if necessary use "wagg bags". The grey tank no problem with that ... except when the darn pump doesn't work.
38,770 PostsLatest Activity: Apr 13, 2026
