Hello jjrbus,
Thank you for your reply and link. Definitely interesting.
Our RT does have the grey and black slide valve handles, but they too do not function as they should anymore. I will have that fixed as well.
Here's an UPDATE on how I got the tanks emptied this weekend.
I put the van on three layers of Link Levellers on the passenger side only of the van. This allowed me to gain access to the macerator and plumbing.
There is a 3 inch ABS clean out/drain with a plug. I placed a 3 1/2 gallon pail under the plug and then loosened the plug until fluid from both tanks started to drain into the pail being careful not to unscrew the plug entirely! I did this several times and emptied the pails down the toilet.
I then used my black tank spray wand and gave the tank another cleaning and then emptied it again. For the first time in a long time, the tank actually registered green on the instrument panel!! SUCCESS ! And no adverse impact to the environment :)
