It was too hot to comfortably work outside today so I turned on the air conditioning and worked inside. I have a Road Star TV antenna by Winegard on the RV. The existing 12 volt signal amplifier did not work so I removed it from inside the wall. I replaced it with a RCA 10dB amplifier that plugs into a 120 volt AC outlet. After I was done, testing showed I still had better reception with the small indoor amplified antenna I had temporarily connected to the TV. I need to do more research on antennas.
