Empty_Nest__Soo's avatar
May 29, 2014
Magnum Chassis
A couple of the brands of motorhome we’re interested in are Safari and Beaver from the late 1990’s. Both are built on Magnum chassis.
I’ve seen enough references to poor handling of Safaris (due mostly to weight distribution issues, apparently). Gives me pause in buying a Safari. I have not heard the same reports about Beaver motorhomes. Beaver floor plans seem very similar to Safari floor plans for the late 1990’s. I’m not sure how similar the other engineering may be.
Do Beaver motorhomes on Magnum chassis for model years 1995 to 1999 have the same issues with handling and ride as their sister Safari motorhomes?
Thanks!
Wayne
  • Ivylog's avatar
    Ivylog
    Explorer III
    Previous MH was a 40' 98 Beaver Patriot on a 8 air bag suspension. Handled well although I probably should have put new shocks on the front as it would bounce a little after hitting a good bump. Some years had a brake recall for the Bosch disk brakes. Nice MH all the way around with a 330Cat/6 spd Allison and the exhaust brake worked really well.
  • wolfe10 wrote:
    Being a big fan of KISS (Keep It Simple Stupid). . . Basement storage generous and with its simple leaf spring suspension, very little maintenance.
    . . . and light weight (under 21,000 loaded) make for good performance and MPG.
    The idea of Simple appeals to me as well. I wish I could find somewhere a credible list of which Safaris had the leaf-spring suspension.
    The lighter weight of an aluminum skin appeals to me also.
    Wayne
  • Wayne,
    Just ask what suspension it has when you inquire about a coach.
    Really only three choices:
    Leaf spring-- clearly identifiable-- yup, you can see the leaf springs.
    Torsilastic, also known as Velvet Ride (my personal opinion, the lesser of the three choices as it has been out of production for over a decade).
    Air suspension (most early ones were 4 air bag). Monaco higher end Safaris 8 air bag.
    If a seller can't tell you that much about his coach, "Run Forest, Run"!
  • Brett,
    Okay, thanks! I had no idea that the suspension types were so distinct and easily identifiable in practice.
    Wayne
    Thanks!
    Wayne
    Have a 98 beaver monterey on a magnum chassis - rides and handles like a dream.
    As good or better than any rig of comparable size and weight and light years beyond a gasser
    Ive towed 7K with it - no bad manners Ive picked up.
    Its good enough that I invested a bunch of dough into it already with zero chassis concerns.
    Ive only got 24K on her, but have already repainted it, and dropped in a diesel genny in place of the propane unit.
    Uncle Dave
