dougrainer
Jul 07, 2019Nomad
Ranger Smith wrote:
So yesterday the batteries went down to 10.5 volts. Did a reset and it came back up to bulk mode with 130 amp on remote for batteries. It apparently charged them. This morning it is back in "batt save" mode and currently at 12.7 volts and showing 0 for current draw on remote. I would think there should be some draw as we are using 12v lights etc.
Yes I am connected to AC and a 50 amp service with both legs operating properly.
I believe the current draw is only when in INVERT mode and not connected to 120. I have NEVER seen a magnum go to 130 amp charge rate. usually the top is about 100 to 110 amps. Now, Are the AGM's ORIGINAL factory installed style batteries? NOT asking if the batteries were original, asking if the Meridian came with AGM's. Why? Because the Magnum has to be SET for charging regular Lead batteries OR AGM batteries. Very few people realize this. The Owner replaces the Lead batteries with AGM's but does not know to set the Magnum for AGM charging. You do the set up thru the remote panel. Verify this and if set for Lead, your new batteries will be ruined in a few months. Doug
