Mile_High
Jul 07, 2019Explorer
dougrainer wrote:
Now, Are the AGM's ORIGINAL factory installed style batteries? NOT asking if the batteries were original, asking if the Meridian came with AGM's. Why? Because the Magnum has to be SET for charging regular Lead batteries OR AGM batteries. Very few people realize this. The Owner replaces the Lead batteries with AGM's but does not know to set the Magnum for AGM charging. You do the set up thru the remote panel. Verify this and if set for Lead, your new batteries will be ruined in a few months. Doug
The 2011 Meridian came factory with four (4) 31 series AGM coach batteries and a Magnum 2000W inverter. With the residential refrigerator option - that got upgraded to six (6) 31 series AGM coach batteries and a Magnum 2800W inverter (2812).
Ranger - you should make sure they didn't change the settings on the Magnum. Under battery type, Use AGM2 for the typical East Penn or Trojan (most brands), or if you installed Lifeline use AGM1.
