Ranger_Smith
Jul 07, 2019Explorer
The batteries are the original style AGM batteries. There are 6 of them. Battery type is set to AGM 2 and the Battery AHRS set to 200. Charge is set to 100% and VAC set to 100
Did a reset this morning via the manual instructions by holding the power button for 15 seconds then let it go. it went through it's blinking lights and clicks. Then turned back on. After that it seems to be working right for now. Is currently in "float" mode.
My panel shows the current draw when ever a light is turned on. If inverting it will say like -23 amps and when on AC it will normally show like +16 then when a light is turned on it will show like +18 to show more draw.
