theoldwizard1
Oct 22, 2017Explorer II
Those are pretty bulletproof engines and so are the transmissions.
Are you still pulling that trailer ? 2 things to learn. What is the rear axle ratio and does it have the biggest radiator available ? (Smaller Ford trucks had 2 different size radiators; standard and heavy duty if equipped with the trailer tow option.)
Bigger radiator is always better. If you are struggling on hills, you may need to change the rear axle ratio to a higher number.
