gutfelt
Oct 23, 2017Explorer
Gjac wrote:
Sorry to hear about the loss of your husband and figuring this stuff out can be daunting. I would suspect that your older DP is probably close to twice what the gas MH weighs. Also compare the HP of your older DP to the 362HP V-10. HP/wt is what will determine your performance. A simple test is to see how long it takes your DP to go from 40-60 MPH on a flat and then test the Gas MH the same way. If the gas MH is quicker and I would suspect it would be you will also be quicker on the hills. Good Luck on finding the right MH for you.
except on the hills the large diesel because of torque will move the load up the hill a lot easier so not true that if gas faster on flat ground it then will be faster on hills
