Jarlaxle
Nov 05, 2017Explorer II
gutfelt wrote:4x4ord wrote:
Engine torque vs HP is hugely misunderstood. A gasonline engine capable of making 500 lb ft of torque @ 3200 rpm will absolutely outpull a diesel engine making 800 lb ft of torque at 1600 rpm. It's not that complicated.
Think of a diesel equipped truck traveling 40 mph with the rear axle turning 400 rpm. When the diesel is delivering its maximum torque on the crankshaft of 800 lb ft at 1600 rpm the torque on the rear axle at 400 rpm will be 3200 lb ft.
The gasoline equipped truck will be in a much lower gear to have the engine running at 3200 rpm while its rear axle is turning 400 rpm. It would be capable of putting 4000 lb ft of torque on the rear axle.
So yes torque is what gets the job done but torque has to be measured and compared on the rear axle to mean anything.
Ok now in the real world take a 425HP 1250 lb torque engine @1600
will your gas engine/torque example still out pull mine?
No it wont even come close and that's why you don't see 360HP ford V10 engines used in a 39-45foot Pusher motor homes that all have diesels the weight is too much for poor/low torque gas engines
Actually (sound of hanging curveball getting launched into the third deck) Ford puts the gas V10 in 33,000lb GVWR F750 medium duty trucks.
