stugpanzer's avatar
stugpanzer
Manual Extend Kwikee Steps
Our Kwikee steps will not extend. I have the manual and found how to troubleshoot with a battery. I checked the fuses and they are both good (Step Switch & Step Motor). I can hear the switch but the motor does nothing. So...with all that said, until I can get to the troubleshooting part, is there any way to manually (with no power) extend the steps?
  • dcbrewer wrote:
    I have a 06 PaceArrow also. I have the step motor off mine right now. You might try tapping the motor with Hammer while someone opens the door. Just don't get your hands in the way because they can move fast, and don't be under them. Mine started sticking last year, and would have to tap motor with hammer to get working. Might need to lube the steps .
    Are you replacing the motor then?
  • I have a 06 PaceArrow also. I have the step motor off mine right now. You might try tapping the motor with Hammer while someone opens the door. Just don't get your hands in the way because they can move fast, and don't be under them. Mine started sticking last year, and would have to tap motor with hammer to get working. Might need to lube the steps .
