bsinmich
Oct 24, 2013Explorer
When my '89 Jamboree was only 2 years 0ld I found out the value of flushing brake fluid. I had an E350 and when I pushed on the brake pedal I went through a red light at the bottom of a hill. After they cooled off everything was OK. Mine was a dragging brake that caused the fluid to heat up. Moisture in brake fluid will boil and become vapor. A gas can be compressed while a fluid can not be compressed. That is the advantage of a MH. Clean underwear are only a step away.
38,763 PostsLatest Activity: Dec 13, 2025
