Whether levels are down or MH is moving, it's lower about 2 inches on the right side. Weight is not an issue. Any ideas on the cause? An appointment with Freightliner may be next....
Leveling jacks extended are not required to repair the chassis Air leveling system. Leveling jacks are an ADD ON option. Now, if you are talking about CLOSING the Air dump solenoid valves(Atwood control box does interface with the Chassis air solenoids), you can jump the air valve wire at the Atwood control box (not the dash touch pad) to close the air valve solenoids. The procedure is outlined in the Atwood operators manual. Doug
