QUOTE: "Actually using a small applicator, available from Dynabeads, you do not even have to take the wheels off of the coach. You just deflate the tire, pull out the valve core, pour in the Dynabeads, insert the valve core, and inflate the tire again."
Equal has a similar applicator to add the balancing powder through the valve stem. If you use Equal, make sure you also use the special valve stem cores with the attached screen to insure you do not get a grain of the powder trapped in the valve core seal and loose air pressure. Dynabeads are much larger so you do not have that problem with them.
