I have used Equal since 2008 which was my first tire change of all six tires.
At that time I had the new Toyo tires installed at a place called Discount Tires in Las Vegas, Nev. Then my third tire change was in 2013 in Barstow, Ca at Pete's tire, and again I had six Toyo tires installed with the Equal balancing bags and air filtered valve stems.
You can not ask for a better ride, smooth and the tires wear out perfectly smooth. None of that cupping or rivering that a lot of coaches have problems with.
