bigred1cav
Feb 26, 2015Explorer
MH Tire Balance
What should one pay for balance of each tire on a MH? Where is it best to have this service completed and what should an alignment cost on a MH?
DSDP Don wrote:
You still didn't say what size rims you have. To add the Equal beads or Dyna beads, they'll have to remove the tires and rims, break down one bead and insert a bag of beads. If they're 22.5" tires, I'm guessing about $35-$50 per tire. A little less if they're 19".
trop-a-cal wrote:
If you use Equal for balancing you never need to have tires balanced, as it is a powder that moves to the spot needed as you drive down the road.
DSDP Don wrote:
What type of motor home and are the tires new, soon to be mounted or already on the coach.
The alignment should be between $150.00 and $200.00. Make sure it's a 4 wheel alignment. They'll connect lasers to the rear wheels to make sure they're tracking the same as the front.
