jadatis wrote:
No, if DOT is on tire the load rating is used but the AT-pressures belonging to plyrating that are sometimes a bit diferent from America.
And so If you have a DOT tire from Europe the chance on confusion about the AT-pressure is only bigger.
Especially for C-load , I think in the past it already had given some wrong tire pressure advice , for instance VW T4 that where delivered to America with sometimes C-load 55 psi tires and then pressure advice going from 50 psi At pressure but with maximum load of 55 psi tire used.
OK buy do your tyres say Load Range or Ply rating or PR ?
