derh20's avatar
derh20
Michelin Tire Pressure
I am not the sharpest tack in the box, but I am having trouble reading Michelin's chart. I have a 29' B+ with 3 slides. I have LT225/75R16 tires. My front weight is 3900lbs (far below the max) and my rear dual axle is 9700lbs (200 lbs over weight). The Michelin chart shows a max at 80lbs PSI to be 2600lbs in the front and 4940lbs in the rear with dual tires. These numbers are far below my weight. What am I not seeing in their chart?
