Escapade's avatar
Escapade
Microwave and front TV zapped?
Just got back from and camping trip and plugged RV into my 50amp box at home. When I entered the coach there was a electrical smell and a brief noise underneath floor. The front TV and microwave are not working nor is the outlets. Ran extension cord to RV and plugged them into it and still not working. I then plugged my surge protector to 50amp outlet and it show ok. Never bother to check outlet at home.
We did have a power outage at home three days ago and power was off about 12 hours while we were gone.
I have checked both AC's, rear TV, Frig, DVD, VCR, and all other outlets are working. Did check switch and microwave outlet was tripped.
The front TV and microwave were working earlier this morning at campground. Where do I go from here??
    Any particular coach? GFI reset?
  • Check each and every appliance that uses 120VAC and each outlet. I suspect that there might be an open ground or bad neutral on the house circuit. Likely you have killed the appliances that arent working.
