cbr46
Feb 02, 2015Explorer
Microwave Crashing Down
Something goes wrong every trip . . . .
2002 Fleetwood Terra, 76,000+ miles
This trip the microwave pulled out of it's overhead mounting and came crashing down on the stove. Fortunately nothing is broken. The stove works (no dents), the uwave works, and my buddy's arm that it hit on the way down isn't broken. The microwave is 50 - 60 lbs (guessing).
Here's the overhead where it mounts -
The bracket -
and the bracket rivet -
You can still see some wood stuck around the rivet.
I could put the bracket back up with LARGE wood screws as I don't have any rivets that large (not real fond of the rivet design anyway). I could add 2 more LARGE screw mounts, or just redrill new holes altogether to penetrate fresh wood. I thought about using expanding drywall bolts but the foam above might not allow them to expand out very much. Toggle bolts, maybe? They would need a much larger ceiling hole but at least pull down tight over a larger area.
Ideas?
Best,
- c bob
The bracket -
Ideas?
Best,
- c bob
