Yes the do have an internal fuse. If it needs replacement the only thing "Special" about an RV Mirowave is venting.. Microwaves come in essentally several flavors when it comes to venting.. Some vent to the front, Rear, Top or one or the other side.
Depending on how the microwave is mounted you may need to "Duct" the vented high moisture air to a specific location.
To show you how "Special" RV microwaves are.. Mine is a "Dometic" it has a metal duct to bring the venting to the front. Open the door and you find out it's an LG (Lucky Goldstar) and like all goldstar products.. I was not lucky enough to get one that worked.. So I had to do a bit of engineering and work on it. IT now works perfectly (Well... I did go to school to study electronics and engineering).
