thcguy12
May 15, 2015Explorer
So I went up last night and raised the rv and set it on some coolers and wood blocks.
I banged the jack portion (the metal pole that goes to ground) with a hammer til it was straight again (very close to straight). Added larger wider pieces of wood stacked higher and lowered it back down. Seems to be pretty sturdy and MUCH straighter than before.
I wish it had front stabilizer jacks - it only has back ones.
Now my next issue - being completely level. It's level front to back. But side to side it's a little lower on one side. You barely notice but you can tell one corner is a little lower. I don't have any way to fix this though - I can't move the camper again to put wood or blocks under tires because I can't my car back in there to hook up. This is more of a comfort issue than any safety issue right?
38,766 PostsLatest Activity: Jan 10, 2026
