et2's avatar
et2
Mixer valve
Ever since we purchased our MH we've had issues with the hot water tank mixer valve. First year we owned ours this valve was replaced as it was noisy. In less than 3 years it needs replacing again.
Doing some research it seems like these are a known problem. Many failing after dewinterizing ( as ours just did). It really never gave consistant water temps.
Just curious if others have had this problem with this mixer valve. I was just told I should remove it and clean it every year. I tried to get the dealer to bypass it but they declined ( insurance reasons I assume).
It's almost $300
  • Just curious......
    Those that 'bypass'---'remove' mixing valve (Atwood XT Models) are you changing out t-stat to lower temp or just leaving the stock 160*F t-stat and then it's user beware (if you even tell anyone) ??
