Gjac
Jan 22, 2021Explorer III
pnichols wrote:Phil you make some good points. However are there any advantage to a lower profile B+ like the Phoenix or BT Cruiser as far as ride quality(lower CG) or better MPG (more aerodynamic)? Do you still tow a car in your 24 ft MH?klutchdust wrote:pnichols wrote:Gjac wrote:
I have been thinking about this issue my self. Most all the small class C’s have this corner bed and would not work well for two older people so one would have to sleep somewhere else. Has anyone tried reclining the front seat and using that to get down in the middle of the night? Can you step on the couch then to the reclined front seat to get up and down.?
Our 24 ft. Class C has a dinette that easily converts into a full bed in addition to a rear corner queen bed and a cabover queen bed. A couple could sleep one in the rear corner queen bed and one in the dinette full bed if neither on one wanted to use the cabover bed.
MY experience with dinette sleepers is they tend to be stiff and uncomfortable but that can be dealt with.I had a high end sleeper sofa from Itasca that we removed and sold because of that.
I personally have a topper in my new (to me)RV that is very comfortable ,but where would you store that if it wasn't on the bed.
I use a 3" foam topper on top of the built-in foam mattress in the overhead cab bed where I sleep. I can sleep in the overhead cab bed without the topper, if I have to, thanks to the nice stock 5-6" foam mattress that Winnebago built-in up there.
When we have a need for the full bed that the dinette makes into, I just borrow the extra 3" foam topper I normally have on the overhead cab bed and use it on this dinette full bed to provide added comfort for whoever sleeps there.
The above is another reason I like the classic Class C configuration with the large overhead cab bed area. Whether it's used for sleeping or not ... it's a great huge interior area that can be put to good use. It also helps shade the cab to keep sun's heat under control, plus there's less water, sleet, or snow blasting the windshield when having to drive in bad weather.
I would never own a so-called Class B+ just because of the more streamlined small overhead cab area. You gain a lot of versatility by having that large overhead cab area of a classic Class C available for whatever.
