2012 coachman free lander i see some moisture in reverse light's. what is best way to find out if leaking around light or coming down from some where. does any one else have this on their unit
I have those cheap Barge? light fixtures that just don't seal well. The cases are made of cheap hard plastic and the lenses don't seal because there is no gasket. I drilled a small hole in the bottom of the lense so moisture can escape. Works for me.
