C20 wrote:
Mountainair,
The battery voltage gauge says 12.5 volts
That should be close to 80/90 % charge. Would be better at 96+ but you also have to ensure meters are good also. If you have a good volt meter use it also.
Here is a link on the cell voltage. You should do this the next time you are having the issue along with a battery voltage check from the post at the battery. It will show if you have a bad cell. Or you can use a hydrometer battery tester. Post the reading. You should be able to test this at home just by running out the slides and using the jacks, say one time and see if it shows up. Then two etc.
voltsGene
