Effy wrote:
So is it better to use a MT LLC to buy a Gas or diesel MH and which manufacturer, length, and should it be new or used and how old should the tires be and what should I expect for MPG? If Gas workhorse or F53, if diesel, should I look for spartan, freightliner or any other? Also, is it better to have my MT LLC coach with hydro slide or electric, tpo roof or fiberglass? Should I ever level it with the wheels off the ground? (Fronts only - I am not that silly). I think that covers most of it.
Nah, Effy, I think you forgot a few topics:
Should you travel in it with propane frig on? Is it OK for you to dump grey water on the ground with it? Should you spend a fortune on day 1 and put in a residential refrigerator? If you tow a vehicle behind it, should you install a supplemental braking system?
Hehehe, it goes on and on. :)
