samandbertaExplorerFeb 09, 2014more powerI have a 2012 Chateau Citation 30 ft Ford 450. I have heard there are several things you can do to give it more power. Any suggestions? Thank you in advance, Sam
pianotunaNomad IIIFeb 09, 2014Hi,I'd have the transmission checked. It sounds as if it may be slipping more than it should. Are you using the tow haul setting.
Related ContentAdding power outlets in slide with no wiringNewbie power question12 Volt Power IssuePower DrainSolar power
