Lurker52
Feb 13, 2019Explorer
Motor home tire pressure
Hello Everyone,
I have a 2001 Monaco Night 36’ DP. My question is about tire pressure. The tires are Goodyear G 661 HAS load range H 255/70 R 22.5 The tires say max. pressure 120#
I am not sure what the correct pressure should be. I have not weighed the RV but I have a Cat Scale ticket from the previous owner. He weighted it ready to travel. Full fuel gear and water.
The ticket shows a total of 27,140# but 3120# of that is his toad. The front weight was 8640#. The rear was 15,380#. If I understand this right that means each front tire has 4320# on each. The rears (duallys) have 3845# on each of the four tires.
The sticker in the coach says to inflate front and rears to 80#. I have looked for an inflation chart on the internet for these tires and have not found an exact match. I have found very similar Goodyears that say the rears should be at 80# and the front at 85#.
When I checked the tires, they are at 90#. I would like to lower the pressure a little to help with handling. The RV has the steering box that is not adjustable and has some play in the wheel and wonders a bit at high way speed 60-65 mph.
Any insight on correct pressure or where I can find a chart is appreciated.
Thanks as always,
Lurker
Thanks as always,
Lurker
