bsshelby's avatar
bsshelby
Motorcraft synthetic blend or switch to full synthetic
Just bought a 2010 Winnebago class C (Ford V10) with 8000 miles. Would like opinions on whether to stay with the Ford Motocraft synthetic blend oil or change to fully synthetic oil. I would be using Valvoline fully synthetic. I appreciate all responses!
Thanks,
Steve
  • chinrv wrote:
    Our 2001 E450, V-10: now over 193,300 miles, using only the Motorcraft synthetic blend 5w-20, along with Motorcraft filters. Enough said?????
    YEAH!!!!!
  • If you can take advantage of extended oil change intervals, then that's a good reason to switch to full synthetic. But if you only change your oil once a year because you don't drive more than 5,000 miles a year, just stick with the blend.
    I run MolyLube/LubroMoly full synthetic, but I also go as far as 12,000 miles between oil changes.
  • Holiday27 wrote:
    I only use Mobil 1 in my rigs. It has served me well over the years. I think full synthetic is the best. Your past the break-in so go for it!
    Me too.
  • Our 2001 E450, V-10: now over 193,300 miles, using only the Motorcraft synthetic blend 5w-20, along with Motorcraft filters. Enough said?????
  • I only use Mobil 1 in my rigs. It has served me well over the years. I think full synthetic is the best. Your past the break-in so go for it!
