Mile High wrote:
Has anyone installed a motorcycle lift on a rear radiator coach? I'm just wondering if the heat from the radiator causes problems with the bike, and if the bike causes problems with airflow.
The previous owner of mine installed a CruiserLift, but maybe it didn't work out and that is why he traded - not sure.
Mile High,
Yes, I did just what you're asking. I installed a Hydralift on the back of our '04 Itasca Horizon 36GD with the CAT C-7 330HP. Yes, it's a rear radiator. After the install, we loaded the bike and headed out on our first trip. It involved the "Baker Grade" that's on the way from San Diego to Las Vegas. It's one pain in the bu.. grade. That coach got a bit warm on that grade, as do many. I pulled over near the top of, a pull off called Haloran Summit and stopped the coach while I got out and checked the bike to see if the heat coming off that rear radiator coach, had any affects on the Hondas paint.
Oh by the way, we were carrying an '08 Honda GL 1800 Goldwing. While the bike was quite warm, I saw no detrimental effects. As for the coach engine getting warm, it was due to a fin-clogged radiator that I didn't know I had. That condition has since been remedied.
So, to answer your question, no, there is no negative effects of the heat coming off the radiator of that coach, on the bike.
Posted By: Chum lee on 04/13/19 02:03pm
Generally, the air coming off the engine of the motorcycle (air cooled) is far hotter than what comes out of the radiator of a diesel engine.
Not exactly. I ran an infrared heat gun in multiple areas of the radiator, the bike, the rear grill of the coach and more and, without a doubt, the heat coming off the rear of that coach is either equal or above that heat that comes off my Wing motor.
Scott
Click For Full-Size Image.
