If you do not have a platform wide enough that you can sit on the bike with both feet down for support from ground up to load level, do not use bike power to load the bike. You may get away with it but eventually it will end ugly. Either with the bike falling and you barely getting out of the way. Or the bike falling and you ending up under it. Like stated above there are systems out there that do this safely. $2000 might seem like a lot but it looks like a really good deal when you are laying in a hospital after being pulled out from under a motorcycle.
