Toddupton wrote:
They would not work. They expand when you put them in however they expand into what? There is no structure behind them to grab. The 1/4 plywood is what is warped and that is really all that is in there to grab on to.
X2...I don't think they'd work. The lamination glue has turned loose and most likely the underlying structure is separated. There's probably nothing behind where you'd drill into to place the rivet. Unless it's a really bad delam, it'll probably be okay since you have stopped the leak.
