becker's avatar
becker
Motorhome Entry Steps
The entry steps on my motorhome have suddenly froze up..... they won't come out or attempt to move one way or the other..... they are very solidly in the "in" position. I get the feeling they are for some reason "just locked up".
Does anyone have a suggestion as to how I can get a "schematic" on these steps? It seems most of these steps operate about the same.
Any help will be appreciated.
  • Check your magnet switch..it could be that the magnet switch is not releasing thus not telling it to release for the steps to go out..one in the door and one in the frame.
  • Battery voltage proper? Our's would do this in the winter when needing charging.
  • wildtoad wrote:
    First thing to do is to lube everything. A lot of time the unit will fail if if detects too much resistance. When you open and close the door do you hear anything clicking or trying to move?
    x2. Use compressed air and whatever it takes to clean all the joints. Then lube well. Use penetrating oil, not WD-40.
    If it turns out to be an electrical problem, you'll have the cleaning and lubing done.
    Please, let us know the problem when you get the steps working.
  • First thing to do is to lube everything. A lot of time the unit will fail if if detects too much resistance. When you open and close the door do you hear anything clicking or trying to move?
