tarnold
May 24, 2017Explorer
As I mentioned, plastic shims. You buy them in packs. As they are plastic, they slide out real easy. I've never had one stuck where I couldn't pull the receiver out. The thick part faces out. Because they are tapered, you only need one, where using old oil plastic, will involve multiple pieces till you get the thickness right. And doesn't involve another wrench to remove another bolt to remove the receiver. Anyway, just a simple solution to a simple problem.
