becker
May 23, 2017Explorer
Motorhome hitch receiver has play in it
I have a 08 Monaco Dynasty..... the hitch is rated at 10,000 lbs.... I have a Roadmaster Blackhawk All Terrain 2 Towing system.... when I slip my Roadmaster hitch bar into the receiver on the coach, there is a little play left to right.... very little, maybe 1/16 to 1/8 inch.... a poster on this blog had the same problem.... he solved it by using another type of lynch pin.... after you inserted it you tightened a nut and it held the tow bar very tight in the receiver and it eliminated the play in the hitch (I may not be explaining the lynch pin correctly).... my question is: has anyone had this problem and solved it in this manner? Thanks
