skiwhiz
Feb 15, 2021Explorer
Mountain Driving
Purchased Cass A Traveller motor home Ford V10 Automatic. Would like hints for driving/barking in mountains, passes etc, all help and suggestions welcome ??????
DrewE wrote:
For climbing hills, don't be afraid to push the V10 and let it rev up. Its powerband is at relatively high RPMs, and it's perfectly capable of running there for quite some time, even if it sounds like it's a giant over-caffeinated bumble bee thrashing about.ReneeG wrote:valhalla360 wrote:
Our 2008 F250 V10 does and it works great. It would be shocking if a much newer MH doesn't.
Well, I learned something new. We had a 1999 V10 F250. No tow/ haul mode, but when we bought our 2011 F350 diesel, it came with a tow/ haul mode and a tap of the break slows it down.
It depends on the transmission (and that depends on the year of the vehicle). The four speed Ford transmission did not have tow/haul, and the button on the shifter is correctly labeled "O/D off". The 5 speed and newer transmissions do have tow/haul instead, and it works well.
A motorhome is always hauling, even if it's not towing, since it's a heavy load and a lot of air resistance. As such, it's not at all unreasonable to always use tow/haul mode if you have it.
ReneeG wrote:
I believe the gasser doesn't have the Tow Haul mode where you can tap the breaks and slow it down like diesels. When we had a V10 truck and towed a travel trailer, we had to do the slow lane with the semi's and slow it way down, then pump the brakes at the end to keep them from seizing up.
I believe what you are thinking of is an exhaust brake. Since a diesel doesn't have a throttle to choke off, it gets very little engine braking effect. An exhaust brake has as similar effect but works by restricting the exhaust rather than the inlet. This is common on most newer diesels.
Worst case, if it doesn't, just manually downshift for a similar effect.
