JCat's avatar
JCat
Explorer III
Oct 05, 2023
Moving forward with flooring replacement
After 20 years the RV flooring is going to be replaced.
We picked out a carpet that is easy to clean and we are going to replace the white ceramic tile with Black Galaxy granite tile.
We are replacing the front step carpet and rubber covers.
Carpet will be same as rest of RV
Step covers will be 3/4 inch Black Galaxy granite.
I am also thinking of adding LED lights in the step area, have not figured it out yet other that being able to wire to existing light wiring.
Planning on spending around $8k for materials and labor, but we will see.
The good part is that all work will be done at my house so I will be able to check on the progress and quality.
I was thinking of replacing the couch but I will need to take it apart and maybe cut it up as my door width is very small.
Also not sure what I can bring in through the door, RV furniture or house furniture, we will see.
If you have done this let me know some lessons learded
  • Granite tiles? How much do they weigh?
    Pianotuna is right, they may not hold up to the flexing and vibration of a MH.
  • Hi,
    I'd be concerned about the floor flexing and cracking the tiles.
    I used a high quality plastic faux wood for the floor replacement.
