- EffyExplorer III have looked at no less than 300 sets of these between Amazon and Ebay with prices from $19 - $80. How in the world do I know which ones to buy? I am looking for the 16ft, multi color (with soft white or dimmer) with remote, with power supply. Anyone find a good source for that? Tested and reliable?
These look decent and low cost.
Cheapos from Ebay - MackteeExplorerThe tape on the ones I bought is like cement and is intended to be on there permanent. And I believe they are right. Macktee
- psw757ExplorerAnyone install these under your coach?
- RonWSlExplorerI got the cheap set off of Amazon (less then $30 as I recall). Bought a roll of 3m tape at Walmart as many on here said the tape that is on the back of them isn't enought, think the tape was about $6. Took less then an hour to put them up. Left the plug at one end of the awning arm, and run a cord up to it. Remote seems to work ok. All in all, not hard to install and for $30 I think they are Great. Can set them on multiple modes, or one of several colors, or white, blink, fade, solid etc. They roll up inside the awning. Had them several months now, used on several trips with no issues.
- MeffrigExplorer
slemnah wrote:
Where are youguys getting your LED light strips?
Steve
Got mine off of EBAY and I think I saved some money. Now if I can only figure out to how to do the wiring (the one I purchased for $35 doesn't come with 12 v adapter).
20 Key RF Wireless Remote LED Controller 12-24V 12A + 2x5050 RGB LED Strip Light
| Add to watch list
Seller : ipartsdepot1 (25152 ) 99% Positive feedback
Follow this seller | See other items | Visit store: ipartsdepot
Item condition:New
Quantity:
More than 10 available / 5 sold - EffyExplorer II
Macktee wrote:
Effy wrote:
Macktee wrote:
Effy, mine came in 39inch strings that fit together and then you could cut off what wasn't needed. Macktee
How do they mount? Screws, adhesive? And I assume it's easier to get the kit with dimmer, power cord etc.
They have adhesive backing. These are the ones with the RF remote, so you don't have to point it right at it, and it has a number of different dimmer settings. They are hardwired in. Macktee
Cool. You have a link to what you bought? - MackteeExplorer
They have adhesive backing. These are the ones with the RF remote, so you don't have to point it right at it, and it has a number of different dimmer settings. They are hardwired in. Macktee - EffyExplorer II
How do they mount? Screws, adhesive? And I assume it's easier to get the kit with dimmer, power cord etc. - MackteeExplorerEffy, mine came in 39inch strings that fit together and then you could cut off what wasn't needed. Macktee
- EffyExplorer IIThese are cool. 2 questions though. How do they attach to the coach? And seems the smallest comes in 16.4 feet. I only need 12. Can they be cut? I can't find smaller lengths. 10 feet would be ideal.
38,763 PostsLatest Activity: Dec 13, 2025
