- EffyExplorer II
Effy wrote:
JesLookin wrote:
I got these LEDs from Amazon:
LEDs
I also ordered the extension cable. I routed mine up over the top & down the ladder. Didn't want to poke any holes in the side of the camper.
So there is a 4pin wire pre made I can buy?. Have a link for that?
ordered this. SHould work. ext cord - paulcardozaExplorerIt's right there on the same AMAZON page:
Customers Who Bought This Item Also Bought
scroll rightEffy wrote:
LEDs
So there is a 4pin wire pre made I can buy?. Have a link for that? - paulcardozaExplorerI was lucky. We have a Girard awning that extends over the front entry door. I ran the light strip along the bottom of the awning mount, about 1/2" away from the wall. I ended it right above the entry light and ran the wiring in behind that fixture. Very clean and neat look. I was then able to put all the light controls in behind the cabinets inside, tapping into a 12v wire in the wall. My setup does not need line of sight either. The remote works from outside just fine, with the controller inside the coach in a cabinet.
- EffyExplorer IISo I received the lights yesterday. Tested them here in the house. THey work great. The remote does not appear to require line of sight. I tested from all angles and distances and it works fine. The adhesive stio that came on it appears to be worthless but I can buy a roll of that. So one final question on the install. I planned on attaching them directly on the wall of the coach just underneath the awning. Originally I had thought about running the power lead inside the awning mounting rail as my outside receptacles are right there and a bin right below that. The only problem with this seems to be that the power lead is really short. The 4 pin connector to the remove receiver is only about 3" long. So I either have to run the lights themselves down through the awning rail, or make a lead. I have never worked with the 4 pin connector lke that but I imagine I could splice it and run a length of it. How did you giys mount yours? I'd rather not drill into the wall if I don't have to.
- EffyExplorer II
emiddleb wrote:
Effy,
I have had this system for 2 years now, still working fine.
The IR receiver... if you click on the Ebay link and look at the picture, the white box has two cables off the top and a plug at the bottom. The plug is where the power transformer connects, the large square plug at the top connects to the LED strip, and the small cable off the top has the IR receiver at the tip. It is a flexible cord with a small lump of dark plastic at the tip facing to one side (has a small bump there.)
Some notes: while many of the strips are marked 'weatherproof' because the strip is encased in plastic, the transformer and white box are not. I have found the IR version to be very fussy about placing the tip of the receiver properly... it is directional off one side only. If I had to do it again I'd do the RF version. Also, if you want to install the strip on the awning roller and you have an awning where the roller rotates as you open and close the awning, you'll have to unplug the cable to the strip before opening/closing.
Thanks for the info. Very helpful. In looking at it I see it now. My plan is to mount the transfomer and box in a lower bin. ANd if I understand correctly I could either mount the IR in a small hole facing out, or use an IR repeater I already have. For the price it's hard to beat if it works right. - emiddlebExplorerEffy,
Some notes: while many of the strips are marked 'weatherproof' because the strip is encased in plastic, the transformer and white box are not. I have found the IR version to be very fussy about placing the tip of the receiver properly... it is directional off one side only. If I had to do it again I'd do the RF version. Also, if you want to install the strip on the awning roller and you have an awning where the roller rotates as you open and close the awning, you'll have to unplug the cable to the strip before opening/closing. - EffyExplorer II
mguay wrote:
Effy wrote:
I have looked at no less than 300 sets of these between Amazon and Ebay with prices from $19 - $80. How in the world do I know which ones to buy? I am looking for the 16ft, multi color (with soft white or dimmer) with remote, with power supply. Anyone find a good source for that? Tested and reliable?
These look decent and low cost.
Cheapos from Ebay
Those are the same as mine. I didn't get the 110v converter with it. I just kept it simple and wired direct to 12v from the basement light.
Doesn't say where the IR reciever is. I would like to mount as seamless as possible. I would like RF but the IR will work if I knew where it was and how to mount. - mguayExplorer
Cheapos from Ebay
38,756 PostsLatest Activity: Sep 23, 2025
