CHIEFTOM
Mar 14, 2020Explorer
Thanks for the class 101 on how to use a test light. I'm 76 years old and have been fixing things my whole life. The use/store switch was my first guess but I would have thought this would interrupt 12 volt power to the 12 v panel on fuse block. but there is power there when not plugged in just not getting out to the lights.
I guess I would be sexist if I said the reply from the RVlady is about what I would expect from someone who has never fixed anything in there life.
I do have a converter not a inverter , sorry about the improper nomenclature.
The use/store switch only has small wires attached to it so I'm assuming it controls a solenoid , most likely one of those that are located close to the coach batteries, which are located under the hood in front of the engines.
All HELP is appreciated. I guess I don't consider recommending I take it to a shop to get repaired help.
