cavie
Mar 14, 2020Explorer
Be sure the reverse polarity fuses (Two or three 30 or 40 amp fuses) on the converter are not blown. Find and check the inline resetable 12 volt fuse within 6 feet of the battery. Be sure the battery disconnect switch is in the use position. Find and check the battery disconect relay. Be sure to check the GFI reset on the inverter.
"Lights and other appliances" is not enough information. We need to know ALL that don't work.
