CHIEFTOM
Mar 17, 2020Explorer
Ok, I checked this morning and I do have power on both sides of the solenoid. but still not getting back to fuse block on converter when not plugged in. When I plug in to shore power 12 volt lights work. After having it plugged into shore power and when I first disconnect the shore power lights stay on but not as bright, got some readings of 8, 9 or even 14 volts at converter fuse panel . Not the same every time. Could it be a bad , poor ground. I check up by the batteries and that ground seemed good. The gen set uses the house batteries not the engine start battery to start and that works fine. Thanks for all the help, I really appreciate it.
