mkguitar
Oct 05, 2015Explorer
on most B's you only need remove a panel and everything is right there in front of you.
this is easy- easy as cleaning jewelry...remove the jet, drop in some rubbing alcohol for awhile.
there is a fine hole which is precision- do NOT try to poke through this with a pin or any tool. an old toothbrush is good
the baffle pulls up out of the stack, I used the rest of the rubbing alcohol from the dish and a scotchbrite pad to clean it up.
then used the pad on a piece of stiff wire to clean the stack...kinda like a bottle cleaner...
and a shop vac to suck out the stuff I loosened.
try the easy and "free" stuff first
mike
mike
38,778 PostsLatest Activity: Jun 06, 2026
