SilverbeastExplorerOct 08, 2013My 2004 Cat 3126e wont startI just purchase a used 2004 Newmar Kountry Star pusher. It has a Cat 3126e 330hp. As a newbee I replaced the Fuel filter dry. Big mistake, I have since filled the filter with ATF and even pressuriz...Show More
JohnnyTExplorer IIOct 08, 2013The problem is that you need to bleed the air past the filter... Once air is in the fuel delivery lines it will need to be bleed.
Related Content2004 V10 rough start & idleWater Heater Leak on start up.Cat 3126E oil levelCat 3126E vs. Cat C7 vs. Cat C12CAT 3126E acceleration power loss after fuel filter change
