msgross
May 25, 2014Explorer
I plan on using PL premium adhesive from Lowes/Home Depot. Get a small caulking gun and a few tubes. You can also buy the small metal plates with holes (check decking section of Lowes) to hold the wood frame together. If you use pressure treated then get decking screws made for PT wood. I would worry about the foam being glued, just cut new foam the exact size and it will stick into the cavity. You can use a touch of the same adhesive. I would replace the wood, glue it to the outside fiberglass and lean a piece of plywood against the outside with weight to make sure it sticks, then finish the inside.
38,736 PostsLatest Activity: Jan 18, 2015
