theoldwizard1
Aug 08, 2017Explorer II
First, how about what year and what engine ?
Second, start with a GOOD radiator flushing. I used TWO bottles of Prestone Radiator Flush and Cleaner.
Start be draining the old coolant
Refill with fresh water and flush chemicals
Drive for at least 30 minutes
Drain and refill with fresh water
Drain, refill with water and drive (I feel this second "rinse" very important)
Drain. Fill with straight coolant and drive
You will likely have too high of a coolant concentration so remove some and replace it with fresh water.
Yes this is time consuming but not difficult and it works very well.
See if you have the factory auxiliary transmission cooler. If you do, then you are godd.
38,769 PostsLatest Activity: Dec 31, 2014
