CharlesinGA
Aug 09, 2017Explorer
rgnprof wrote:
And I did have to pull the distributor to pull the intake manifold...I marked everything very carefully and after some difficulty got the distributor back in to what I thought was the same place...
ryan
Did you use a timing light and follow the proper procedure for checking timing?
It probably involves disconnecting a single connector that forces the electronics to a fixed setting and then using the light to set the timing to whatever is on the underhood decal, most likely ten degrees and then reconnecting the connector. You cannot guess at this.
This is a Ford EEC IV system, they all work about the same but you need to set the timing properly and accurately.
Charles
38,769 PostsLatest Activity: Apr 24, 2002
